In passing, optional configurations to support each person's A/V setup can sometimes be problematic. And then there's device compatibility to consider, especially when HDMI is concerned (although this is improving, but certainly still "delicate").
When I bought my HDMI Realiser A8 I had initially planned to send HDMI output from my Oppo 103 (set to decode audio to discrete multi-channel LPCM and deliver that out via HDMI), so as to feed the Realiser's HDMI input with the expected LPCM format. Then I was going to use the HDMI output of the Realiser to go on to my Yamaha RX-V867 AVR's HDMI input, to pass through the video through the AVR and its HDMI output, on to my Panny 65VT50 HDTV. That was the plan.
Well, there was an HDMI compatibility issue, with all of these HDMI devices serially daisy-chain connected. Even though all the devices handling audio were capable of accepting multi-channel audio input, somehow that message wasn't getting back to the Oppo source device properly. So it [mistakenly] thought only 2-channel stereo was supported in the audio chain, and this prevented the Oppo from putting out multi-channel audio. It's been a while now (since 2013) and I can't quite remember everything that happened, but I think I also wasn't even able to get video delivered to the HDTV. Something about a compatibility issue injecting the Yamaha AVR in the sequence.
Anyway, in the end, the issue was simply insurmountable. Something about the HDMI output from the Realiser wasn't fully compatible with the next two downstream devices, and this impacted what the upstream Oppo 103 source box was "willing to deliver" over HDMI, where HDCP and copy-protection is of concern. I had to flush my original system schematic plan.
Instead, I took advantage of the TWO available HDMI outputs on the Oppo 103, and its ability to configure it in "split A/V mode" which supports sending video-only out of the Oppo's HDMI1 and audio-only out of the Oppo's HDMI2. This was my solution.
So I sent HDMI2 out of the Oppo to the Realiser's HDMI input (with nothing connected to the HDMI output of the Realiser). Configured to decode to LPCM, the Oppo is thus delivering decoded audio-only LPCM to the Realiser's HDMI input. And with nothing HDMI-downstream from the Realiser to "confuse" the upstream Oppo, and with the Oppo configured in "split A/V mode", there was no no problem at all delivering the perfect format discrete multi-channel LPCM from Oppo to Realiser via HDMI2 out of the Oppo.
And I sent HDMI1 out of the Oppo carrying video-only to the HDMI input of the Yamaha AVR's HDMI input. I was not in need of audio/video handling in the AVR when using the Realiser for audio. I only needed the AVR to handle video and pass it on straight through to the Panny HDTV from the HDMI output of the AVR (and with no video processing performed, although in theory it could have been done in the AVR). This utilizes the video processing capability of the Oppo, feeding HDMI pass-through from the Oppo's HDMI1 output through the AVR and its HDMI output, and on to the HDTV. With only the usual AVR and downstream HDTV connected through HDMI1 out of the Oppo, there is no compatibility problem and video is sent unimpeded from Oppo through AVR and on to HDTV.
This "split A/V mode" capability of the Oppo provides two completely separate and independent HDMI paths: (a) HDMI1 for video-only, to the AVR and on to the HDTV, and (b) HDMI2 for audio-only, carrying decoded multi-channel LPCM to the Realiser.
And the way this "split A/V mode" works is that if you actually wanted to use real loudspeakers instead of listening through Realiser-enabled headphones, you can do that too. You simply don't have the HDMI2 path powered on (i.e. you have the Realiser powered off, in standby) and that causes the Oppo to revert to sending both audio and video out over HDMI1. Since HDMI1 goes the AVR it is now receiving both audio and video from the Oppo source device, and handling all of the normal audio and video services it needs to. This allows you to optionally use all the regular audio capabilities of your AVR and external speakers instead of listening through the Realiser. You simply power the Realiser off and now both audio and video get delivered out HDMI1 of the Oppo to HDMI input of the AVR, and everything now is perfectly standard and normal. Video and audio are sent out together to the HDMI input of the AVR, with video then sent on to the HDTV and audio is sent to the AVR-connected loudspeakers.
Bottom line: by using a source box like the Oppo with two separate HDMI output paths, one HDMI1 for video-only destined for AVR and HDTV, and a second HDMI2 for audio-only destined for Realiser A8/A16, and an optional configuration (with Realiser powered off in standby) to send both audio and video out over HDMI1 to the AVR for processing and handling, you have complete freedom to deal with UHD 4K, HDR, etc., with nothing at all depending on any Realiser video capabilities or deficiencies. You're using the Realiser as an audio-only device, which after all is what this product is all about. Also possessing HDMI-output (for pass-through to other downstream device(s)) is really for complex connectivity convenience, say if you didn't have an Oppo source device with two HDMI outputs. I personally wouldn't think of the absence of HDMI 2.0a compatibility in the HDMI-passthrough to be a "deal breaker", considering what the A16 is really all about as far as its remarkable audio processing capabilities. Think of an Oppo as your "solution" to this video problem, rather than not wanting an A16 because it couldn't pass through HDR video.
With a flexible source device like the Oppo the AVR and HDTV are fed video independently, through their own separate HDMI path. If your source device and AVR and HDTV support HDMI 2.0a and HDR, fine. You can still support that with zero dependency on the Realiser. You just need something like the Oppo with two HDMI outputs as your primary source device and an available configuration like "split A/V mode" to create two separate video-only and audio-only HDMI output paths (along with a third optional audio/video combined HDMI output path which does not go through the Realiser, so there's no HDMI version compatibility consideration).
