Just one more thing to say...
In addition to my AIX PRIRs I also have four other PRIR's, all made through personal measurements AT the particular location, and NONE of them do I ever use to actually listen to anything for real:
(a) Mi Casa studio, also made in 2009 in LA, which sounds kind of "hard" and exhibits an "echo" in the room which I don't recall but which obviously the ear-mics picked up. Obviously the speakers and overall sound treatments on floor, walls and ceiling produced a sound which I'm not crazy about.
(b) Egyptian Theater in Hollywood, special invitation, sitting balcony 1st-row-center (with absolutely nobody in the theater), which is amazingly "spacious" but not really good to listen through in my bedroom as not surprisingly it sounds "hollow, cavernous, and has an echo". You're very definitely "far away" from the 30-speakers in the theater all around the front, sides, and rear of my seat location. Listening through this PRIR is kind for the novelty effect of it, but not really for everyday listening.
(c) Glenn Poor's Audio, Champaign IL, which shows poor side/rear surround speaker locations and overall balance, and is not very "warm". Too small a room, and it sounds it through the PRIR.
(d) Smyth sample test room in Camarillo CA, which was taken back in 2008 when I was invited for a basic speaker pre-release (by a year!) demo of the technology, rather than using high-end speakers
All four of these naturally have their own unique characteristics when listened back through, as all involved being measured in completely different physical space layouts with completely different speakers/electronics, echo baffling treatments on walls and ceiling, wood vs. carpet floor, placement of my seat, etc. But in actual life NONE OF THEM IS EVER USED TO ACTUALLY LISTEN THROUGH since the day they were captured! I've even stopped trying to re-listen to them just to remind myself of how they sounded, as the novelty has worn off. None of these is "enjoyable", and none of these are "completely transparent and real" like the AIX PRIR sounds.
The AIX room had wood floor, sound-baffle treatments on walls and ceiling, a terrific shape and speaker locations, and wonderful B&W speakers... all producing a fabulous anechoic but "warm" sound as you sat there. And listening through its PRIR conveys exactly the same "warm" sound, with NO echo anywhere. It's just sound coming from those speakers. I don't want to listen to anything through any other PRIR.
So in reality I use only the original AIX 5.1 and 7.1 PRIRs, with the 5.1 PRIR being my default P1-preset so that I'm automatically listening through it when powering the unit on. I never change it ever, except to go to the 7.1 version (in P2) when listening to 7-channel source. It's the same Stax HPEQ and my supporting amp/DAC equipment that is used for all of these PRIR's, but only the AIX mixing room sound is "enjoyable" enough to use 100% for any type of source. I just would never choose to listen to any of the other rooms, through their PRIRs and the A8 and headphones, because the sound of those other REAL rooms wasn't really "enjoyable" in the actual real world.
While this whole SVS technology is amazing, and if you've just experienced it or had a demo for the first time it's going to be novel and remarkable. But once you settle in and just begin using it everyday as the way you listen to anything, as if you were going to that same sound room you had the PRIR measured in, the more you begin to forget about how it works. The more you will just appreciate the fact that you have the opportunity to be able to listen through a fabulous PRIR-enabled virtual listening environment that sounds completely like real speakers, and that you would probably never be able to build or afford yourself (or even physically have in my 3rd-floor condo with neighbors down below me).
That's my recommendation: seek out a real world listening environment that is ENJOYABLE to hear all types of sound through, and capture a PRIR there. You will then make this your own P1-default, I'm sure.
