Singxer SU-1 Owners
Discussion in 'Dedicated Source Components' started by t bone, Mar 7, 2017.
20 21 22 23 24 25 26 27 28 29
31 32 33 34 35 36 37 38 39 40
  1. enigmus12
  2. enigmus12
  3. rafabro
    Another variation on SU1. But they didn't replace capacitors on main pcb - those have huge impact on SQ.
  4. Thenewguy007
    Any chance you could re-upload the pictures? Seems they are down on photobucket.
    I understand removing the IEC inlet, but there is one wire attached to the inlet & another to the board that seems attached with a lug nut & screw. How is this removed?
  5. oneguy
    I believe it’s a 5 or 5.5mm nut so use a socket.
  6. Thenewguy007
    Anyone know what the Ultracap LPS-1 voltage setting should be if ever used with the SU-1?
    Should it be set to 3.5v, 5v, or 7v?
  7. oneguy
    5v
  8. bflat
    Dumb question, can the SU-1 connect to more than one DAC simultaneously. For example I2S and Coax simultaneously? Or can it only output to one DAC at a time?
  9. T Bone
    That's actually a pretty good question. While I've never tried it - I believe that the output to all channels occurs simultaneously.
    There isn't a switch on the Singxer that forces you to choose a single output, therefore I believe the output is available simultaneously.
  10. ZGojira
    Yes, it works. I currently have all the outputs connected to something.
    bflat likes this.
  11. Astral Abyss
    As @ZGojira said, it works great. It adds a lot of value to the SU-1. I2S and coax just so happens to be what I'm using with mine as well.
    bflat likes this.
  12. Triplefun
    Please confirm that you only need to set the internal slider to change from 110v to 220v.
  13. gvl2016
    Can anyone with the SU-1 help me please, is there a 16-bit output setting in the XMOS driver control panel like the following or only 24 and 32 bit?
  14. elan120
    If I recall correctly, it does have either 16bit or 24bit, but no 32bit from the pull down menu.
  15. LoryWiv
    I believe so, but I m currently using the Holo Audio driver with my SU-1, works great and it definitely does offer 16-bit output option..
