bflat
Ah, no optical. Just COAX. That explains it. Thanks!
I think it’s Ghent Audio.I swapped out my power supply to use an external UpTone lps1
What is the custom Chinese company where I can order a custom DC power cable?
ThanksI think it’s Ghent Audio.
Thanks
Make sure to ask for JSSG option. It is not listed on their website, so if you order directly from website, you will get the non-JSSG version.
Not knowing what "doesn't work with the LPS1 & SU-1" means, the lack of JSSG should not be part of that issue, since JSSG option is to help reduce possible high frequency noise, and would not make the cable "not working". What isn't working on your cable?I bought the Ghent Audio DC cable & it doesn't work with the LPS1 & SU-1.
Did the lack of the JSSG option have anything to do with it?
I ordered the stand plug type, it sorta fits
This is the one I bought (on top) compared to the regular cable I'm using at the bottom.
The plug types seem to be the same, except it's a little longer the Ghent.
Did you order your cable from http://ghentaudio.com/part/list-dc.html
The "standard" plug doesn't look like is an option from Ghent Audio though.
For DC plugs, the length doesn't matter as long as it's a couple mm different. The outside diameter looks about the same so there are a few possibilities:
1) inside diameter of the plug could be different. For the most common 5.5mm plug, there are 2 different inside diameters - 2.1 and 2.5 mm. Most receptacles work with both but not all.
Kinda looks different from my stock cable, could be it?
