NoNameNPC
Is occ power cord improve sq of su-1?
I already install sparkos on 5v and 3.3v.
Go with a good quality 5VDC power supply capable to deliver more than 1.5A of current. DC input plug either 2.1 or 2.5mm will work, but 2.1mm is more common in DC cable selections.When im modding the Singxer SU 1 with this:
https://www.ebay.com.hk/itm/323284909987
which Powersupply do i need for europe how much volt and ampere? im a bit confused becaude ifi does offer multiple choices. Also do you recommend 2.1mm oder 2.5mm?
...snake, oil?cables of silver or silver clad wire isolated with cotton soaked in oil.
Installed 5.58, works flawlessly but not certain what if any changes are evident. Nontheless, happy to be running the latest driver version, so thanks for the heads up @NoNameNPC!I don't know. But maybe this may help https://www.denafrips.com/single-post/thesycon-v5-57-0-usb-driver-windows
But I'm not sure if it's the same for Denafrips and Singxer.
