moedawg140
Grand Master Moe "G"….Don't crossface me, bro!
Ping Pong Champ: SF Meet (2016,2017), CanJams (London 2016, RMAF 2016, NYC 2017, SoCal 2017, RMAF 2017)
Quick question. Which third party cable manufacturers have MMCX connectors that hold a tight connection and don't cut out sound? This at least used to be a big issue when I got my SE846 so I kept away from custom cables. My Logitech MMCX cables cut off the sound all the time and the connection is quite wobbly.
Looking for a decently priced cable, not that concerned with possible sound changes. Just something more ergonomic. The stock cable is way too stiff compared to the standard Westone/Earsonics/Logitech stuff.
My Ted Allen (headphonelounge.com) cables have a really solid MMCX connection (tighter than stock cables), and can come with washer rings to help create an even tighter connection (I never needed to use them). No sound would cut out as a result of the super tight connection. Never needed to use DeOxit or anything like that for the connections to try and diagnose/fix cut-out errors either.
