deleted
I just want to note something that I think is important when comparing the 846's to all of the CIEMs mentioned on this page. It's not that fair of a comparison. When the 846's came out it would've been more of a fair comparison (for some of them), but not so much anymore. The retail price of the 846's is still $1,000, but if you don't want to pay $1,000 and are somewhat patient, you can pick up a new pair (as I know many of us did) for under $800. I got mine to my door for $780. Say let's add in the cost of scs and silver litz cables (Let's call each of those $200 upgrades. So (quite roughly), you're looking at $1,180 for 846's that are quite like a CIEM. That price (also consider the price of ear impressions on top of the price of all those customs) is below all of the customs you guys mentioned. It's a very significant amount below some of them. I don't see why all of those JH CIEM's (the ones mentioned) wouldn't sound better than the 846's, they cost more. A lot more if you take away the silver litz cable. On top of that, with the 846's, you get way higher resale value if you wanted to go for those higher end CIEM's, and the tunable filters for everyone's sound signature preferences.
Just my two cents that I don't think it's quite a fair comparison with some of the CIEMs mentioned.
Apropos the recent conversation here about the earbud posts coming loose that lisztian420 kicked off--last night I changed out the filters for the first time since December, to see how the whites sound with my new AK120II, and discovered that the lock rings on my 846's had indeed started to come loose. Each one was perhaps half-way unscrewed, and I feel lucky that I caught it before they had gone completely
I've changed out the tips quite a few times in the past several months and didn't notice any loosening of the metal posts before. This time, the gaps between the lock rings and earbuds caught my eye. I had noticed that the SQ wasn't quite as delicious as I expected it to be with my upgraded DAP, and now I know why. With the posts properly tightened down again, all is well. I can't quite say whether they loosened up gradually, or suddenly, but I think I would have noticed whether the posts had any wiggle to them while changing tips. Anyway, I'm definitely going to make sure the check the lock rings at least once a month from here on out.
BTW so far, I'm really liking the focus on vocals and melody that I'm getting from the white filters. I've never been a huge bass head to begin with, but that's partially because I haven't had phones up to the task until recently. I should also say that I think my slight hearing loss in the mid treble range is probably a factor here, since in effect the filters are undoubtedly EQ'ing some of that loss back.
when u remove the foam from the blue filter is there still part of a ring foam left inside or nothing at all, I mean once u remove u the foam do u see anything left in the filter
what happens if u loose those foams, can u put any foam instead or those special foams
Blues have a bottom foam in a casket.
do u know where i can buy extra pairs of blue and black filters
