x RELIC x
Guys, this is his first exposure to this sort of thing. KrumpyCakes is being recommended to be thrown in to the deep end, all the way to the cable side which should be the very last upgrade possible. What do you think is going to happen when this high end revealing gear shows dynamic compression or bit rate compression or poorly mastered tracks he isn't used to hearing in music and can't identify the problem? He'll be very unhappy at the outlay of cash and then spend hours wondering/asking why it doesn't work as advertised.
My advice is to spend $200 US on a FiiO X3 II and listen to that with the Shure SE846 and get used to that first. Coming from a phone you should be pleased at the sound quality possible. You can still hear flaws in the recordings or pick out poorly produced music easily but the frustration will be much less because the outlay is much less. It gets better from there but at massively diminishing returns. After a while KrumpyCakes can have a better understanding of the terminology, exposure to high res files and he can determine for himself if the upgrades are worth it.
I'll just say that without going on the journey one can not appreciate the higher end gear for the nuances they offer. Something like the X3 II is relatively cheap and hits well above its price in performance so it's a fantastic place to start.
Edit: The DAC in the X3 II is the same one used in the AK240, just in single configuration, and is implemented very well.
