Sound Eq
- Nov 9, 2013
is the mod so much changing the sound signature of the 846
The first thing i noticed apart from clarity and treble was how clean the bass was and i've been hearing with stock blue without much swapping for over 6 months.I can't be alone in this!
I haven't modded the blue filters yet but I'm guessing you take out the bits of foam from the "fat" end right? The end that actually sits in the bezel
You remove the foam from the end that goes into your ear.
Look at the link Jazzi posted (post 10567). The opposite end from the orange O-ring is the foam side. You can actually see the filters create a dark area at the end of the insert that link picture.
For the most part taking the foam out seems to open up treble. I don't find that the lows are affected much. This might also relate to your source and source material.
