fablestruck
I understand. Thanks a lot.I have a V60 and use a 3.5mm aux extension cable to trigger AUX mode (not sure how to trigger high impedance >50 ohm mode). You need to connect the extension cable first without the IEMs connected and then connect the IEMs afterwards. This will trick the LG into aux mode. I believe this works for older models as well. This is the cable I use (need it for the dual screen case due to the thickness of the case):
3 Pack Headset Audio Jack Extender, 3.5mm Headphone AUX Extension Adapter for Juice Pack, for Battery Charger Case, Power Case, for Smartphones, Tablets https://a.co/d/4ybbtU4
I use the Hi Fi Status (LG) app to monitor the status.
EDIT @jjazzy - For portable use, I also have the Dragonfly Cobalt and for home, I primarily use the RME ADI-2 and also use the Grace m900 and Aurender FLOW in some secondary setups. All have very low output impedance and work well with the SE846.
I already have HiFiStatus installed so I'll check my results.
I also have Cobalt, but while I consider it a good much soundwise the extreme volume level it's annoying. I run se846 at around 5-8 % or so.
Much prefer Mojo with se846 which pretty much changed my opinion about these IEMs.
