fablestruck
Do you have any objective measurements about your position here?You have to look deeper, the biggest trick for audiophiles is that Shure originally made the se846 for professional use. And contrary to Impedance of only 9 Ohms, a portable device simply cannot reveal full potential se846. Because se846 has such a driver design. And Shure wanted mass sales and came up with filters to get out of the situation and this could somehow work with portable devices.
As I already wrote, no one hears Everyone complains about the lack of high frequencies after 12kHz. But this is due to filters and use of portable devices. If you put on a white filter without a cap, you get clear sound from the speaker directly into your ear.
And on a professional audio interface, you can hear the entire frequency range up to 18kHz in a clean and transparent way, not at harsh
But a portable device cannot provide this.
And yesterday I tested it, I took a few high end portables from my co-workers and listened directly to the comparisons and switched to my MixPre - and yes, the difference is huge especially after 7kHz
And yesterday I tried the RMCE-TW2 again - and again no matter what I do with the settings - the sound is very weak with any filters compared to a direct connection to the MixPre. It's not about volume (the volume is enough) it is the sound - it cannot be compared with MixPre
This once again proves what I wrote above - these iem were originally designed for professional use with stationary professional audio interfaces for monitoring and recording sound.
The problem in this controversy lies only in the fact that everything is known in comparison and how ready your ears, my friends
And once again - silicone sleeves distort the sound. For correct sound delivery, you need foam with the correct hole diameter and the correct length of exit after the nozzle. The sound from the correct foam comes out unchanged and gives the correct frequency range, width and stereo panorama.
Silicon is killing it.
This is the design of the se 846 and that is why Shure made its silicone with a hole of a narrow diameter and without exit segment after the nozzle
You seem an uncompromising purist (not a bad thing- I used to be like
that before I was spoiled) but this comes sometimes with substantial
cognitive bias, my friend.
