OG10
Are there any after market ear tips worth a look at ?
Are there any after market ear tips worth a look at ?[/QUOTE
I’ve been using the Spinfits for nearly 3 months, I absolutely love them, coming from a person who has used the stock grey, and darker (compression) tips. The Spinfits are fantastic. They come in s,m,l and seem to be about the same size as Shure.
I haven’t paid attention to the sound signature difference much...they sound great and offer a bit better isolation. Cheers.
SpinFit CP800-M – Patented Silicone Eartips for Replacement (2 Pairs, Medium) (2mm Nozzle Dia.) https://www.amazon.com/dp/B01B7AMXDI/ref=cm_sw_r_cp_api_i_ZJKjCbKN06CKX
I tried Spinfits, but couldn't get as good a seal as the triple flanges. If the triple flanges are too much, you can cut one of the flanges off to make a double flange.
If you like bass then comply isolation series are the best in my opinion.Are there any after market ear tips worth a look at ?
Had the exact same experience with those Symbios!I find Symbio provide best sound and isolation but damn they hurt after an hour or two (tried both large and medium).
Spinfits are soooo comfortable but I can notice a big drop in isolation...
i'm glad i didn't settle for the provided foam tips as they are not good in comparison to the others recently mentioned (in my opinion).Or you could just use the Shure foam tips and not worry about stuff, lol.
In fact, until a perfect fit is found, the sq from the ear phones is just average. with a good seal, the sq is excellent.
