Gentlemen (and gentlewomen), I present to you the holy grail of tips: the Olive-Comply hybrid.
Is that an Olive with a hard rubber jacket?
Where do you buy them?Gentlemen (and gentlewomen), I present to you the holy grail of tips: the Olive-Comply hybrid.
Not quite sure what you've done there buddy. The blue filters used to come with only one piece of foam; later versions came with two. But in either case, I believe the factory stock condition is for the foam (or both foams) to sit at the nozzle end (NE) of the filter tube:Performed the foam removal from the blue filters... but didn't have anything to get the bit nearest the damper end out. The usual recommendations have been for both to be removed, or the end foam to be push to the top, but not what I've done. @csglinux any notes on FR shifts pertaining to this?
You need pretty good eyesight to check, but there shouldn't be anything at the other end. Sounds like you've successfully created a modded blue filter!
I removed the foam from the nozzle end. From what I could see/tell there was only a single piece, so could be I have the older filters. I'd assumed there was another piece of foam up the tube nearest the filter end, just before/underneath the damper, but sounds like I've remembered incorrectly.
