ropie
- Dec 30, 2013
two questions.... one - the comply foam tip got stuck to the inner rubber part (not the nozzle - and I can't get it off..any suggestions on how to remove it? its like its glued on- I tried putting it in the freezer no luck. Does anyone know how to order replacement filters? Right now I only have the blue ones. thanks !
1 The Shures nozzle is made of steel, not rubber. The Comply foam tip has a plastic/rubber inner part and foam outer part. I am not sure what you mean exactly, but to me it sounds like you arre trying to separate the foam and the plastic of the Comply tips, instead of removing the Comply tip from the Shure nozzle?
To remove the tip; just grab the foam firmly (give it a good squeeze) and then twist and pull gently.
2 To order spare filters, you should contact Shure directly
