tbritton
Here is another test - a sweep test that covers the range of human hearing. (Thanks to SilverEars)
Terry
Terry
I just read about some audio fit tests that are at the Sensaphonics website. You could check them out to ensure you have a good fit going on, perhaps. http://www.sensaphonics.com/test
(Thanks to moedawg140)
Terry
Hi,
To read all about the Sensaphonics Custom Sleeves and impressions from owners, feel free to check out the SCS review thread, here: http://www.head-fi.org/t/723306/review-sensaphonics-custom-sleeves-in-crystal-blue-for-the-shure-se846.
I have that well bookmarked - it is a treasure trove!
I've read a couple hundred posts of yours from back in 2014, Moe -- I feel like I know all of that gang from then. Coming out of lurker mode after many years absent. With my 8's!!!
Terry
moedawg140
Well, this is so funny. I've been reading the old posts on the thread, starting with about 200 or so. I was reading page 384 and stopped to do my post above about getting my 8's, and later posted that silly virtual haircut piece (uh... to test left and right channels, of course!)
So, I return to page 384 and what do I find as I scroll down a bit from where I had left off? You had posted the virtual haircut!
Talk about strangely connected...
Good to connect with you after getting to know you a bit "virtually" this last few weeks via this awesome thread!
Terry
Maybe the foam not fit properly, thats why ur hearing grainy mids and highsHey guys! Noob to high end IEMs here. My main rig is Audeze LCD-Xs with Dana Lazuli cables, Woo Audio WA-22 amp, and a Chord Mojo as DAC. Just got the SE846s yesterday and the first hour or two of listening sounded awful. I tried every tip and filter but still..very compressed soundstage and all sorts of grainy mids and highs. Not even close to what I was expecting for $1k. Do I need to let them burn in for a while? If so, how long and what kinds of improvements should I hear?
No burn-in is required of this kind of IEM, according to Shure themselves, but brain burn-in may be needed as you get used to the sound. I do not know what a "grainy mid and high" sounds like myself, so I cannot answer to that claim. My 846's sound amazing to me now that I have the tip/filter stuff worked out for my personal scenario (ear canals, preferences, etc.) See my post two posts up.
These are very low impedance IEMs at only 9 ohms. Is your amp's output impedance low enough for these? That is another major consideration. Also, be very careful when re-assemblng the filters, as it is easy to have them dislodge as you screw on the retainer ring so you do not actually have the correct placement.
The soundstage is very wide with mine. Keep messing with the tips and be sure you have a good combo going with your filters.
Terry
Knew I spoke too soon. I'm a firm believer in burn-in for everything, cables, drivers, tubes, etc. And what do ya know..these things are sounding better and wider the more hours I put on them. As far as amping I'm only using my Mojo or just Tidal straight from iPhone. Good tip on the filter assembling though..I may have overlooked that. Unfortunately the only tips that fit my tiny ears comfortably are the smallest grey rubber ones. The others don't seal right or cause pain for long term use. I'm groovin to these things now. I hope they keep improving as time goes on. I can still hear a bit of unnatural harshness in the mids and highs but far better than they were fresh from the box.
Another important test to check on several factors.
