Hachiko270296
Aka: TheReem and numerous other aliases.
- Mar 19, 2015
What's with al the durability problems in reviews? Seems a lot. Should I be concerned?
try westone star tips ...Most people swear by Shure Olives. I'm assuming the Olives are the black foam eartips, the ones that come already installed on the SE535? I received the SE535 today and tried the black foam tips that were already installed on the IEM's. Hated the sound. I typically use Medium to Medium-Large eartips. So I tried the Medium Gray Silicone tips and got great isolation and the bass extension improved greatly. Awesome sound!!! So it appears that the silicones work best for me. I'm totally happy with the Shure Silcone eartips, but just wandering if there is a better brand/aftermarket silicone eartip that works better than the Shure Silicones?
Thanks.
Thanks.
What about the Yellow ring tips? How do they sound
The yellow foam tips have a different sound ... not so much isolated, more emphasis on the high frequencies .. tighter bass ... I would use them full time but they are just so uncomfortable (itchy, fragile, etc.) ...
I think it depends on your ears, all of them except for the yellow ones irritate my ears including the olive ones.
The yellow ones give me the best isolation/sound/comfort, the triple flange ones also gave me great sound and isolation but where very uncomfortable, the silicon ones would not stay in and the olive foam ones gave good sound and isolation as long as inserted carefully but hurt my ears after a while.
Got some Comply P-100's on order to try to compare but if they not as good as the yellows I will just be buying a pack of yellows spare
That's interesting ... I treat the "black olives" like any other "squeeze and insert" tip (think yellows) and for the life of me, I've never heard better sound isolation from any tip, *ever*; hell, I've never even used any actual sound dampening ear plugs that isolate as well. I think a lot of people just sort of press the olives in ... but I've always compressed them by rolling them between my fingers and then inserting and holding them firmly until the expand.
I like the sound of the yellows a *lot* .. it's clean and crisp and not quite as "thick/wollen" as the olives but the relatively smooth surface of the olives just work better for my ear canal than do the slightly rough exteriors of the yellows...
I still switch up between the olives and the yellows, quite frequently ... but the majority of my time is spent with the olives ...
Thanks for the reply .. interesting differences in user experience ...
Cheers.
Just got the Comply Professional P-100's Medium size and so far they seem more comfortable than the rest and have awesome isolation and sound, so I have my personal winner for now
After using the Comply for a couple of days, my ears start to get irritated, so yellows actually seem better for my ears.
