tchpeng
- May 17, 2011
I own a pair of bronze se535...
It was really well build, especially the cable and the connector ....
I bought the SE425 over the 535 when I had the choice as well.
In terms of being 'good' at a wider range of genre, the SE535 is definitely better at a wider range. On the other hand, the SE425 is a very laidback earphones, which can mean 'boring' to some genres. However, if you ask me, its laidbackness is very relaxing and gives a very refreshing change of pace where I simply listen to the flow of the music instead of everything else. And yes, the SE425 does that better than the SE535.
I have a comparison written for those two. Just got the summary left, so I'll probably post it tomorrow or something.
On the other note, W4 is coming in for me sometime this week. So, I'll definitely let you guys know my impressions.
Can't wait to read it.
I find that the black cable is quite a bit softer (and maybe lighter) than the clear. The wire on the clear is just a little bit heavier and stiffer, especially around the memory wire. This is from memory though...
I'm just curious... did anyone included those earphones in a general top, like the one from here?
http://www.head-fi.org/forum/thread/478568/multi-iem-review-172-iems-compared-xears-xr120pro-ii-kozee-e100-added-06-01
I would be interested to see a comparison top between more top-model earphones, in order to make a decision about what I can buy in maximum 500USD.
Someone would recommend Westone or 1964 Ears, instead of Shure SE535?
Any1 that has tried out this third party cable -
http://cgi.ebay.co.uk/Pearl-Ver-2-Upgrade-Cable-SHURE-SE535-425-/270680717646?pt=Other_MP3_Player_Accessories&hash=item3f05d3f94e#ht_1231wt_907
or has a better one to recommend.
I use Pearl V2. While I don't have experience with any other third party cable, I love it.
Even if I get PAID to use the factory cable again, I will say no.
<So what's the actual difference, can you be more specific.
Thanks
Hi there audio geeks.
Is there such a thing as "burning in"? Will the sound of my 535s improve with time?
Thanks!
When you guys go places, do you use the case to carry them around? I have for the last week or so, but the case is big, so when i have nice shorts on or their tight, i dont want to have some case sticking out.
I use an empty Altoids mint case for transport of all of my IEMs. It's flatter, offer great protection, and is a nice alternative to the Shure case.
