I've heard the Tape 2 is gonna be released soon, is that true? Any details?
Shuoer impressions thread
- Thread starter SciOC
- Tags
- ej07 shuoer shuoer s10 shuoer tape tape
Tape 2 was supposedly out in Aug - thru my mate who’s now living in China from local gossips
Stay tuned they must be working on finalising and will come out soon (fingers crossed)
Sorry to hear - indeed QA seemed to be some issues with the Tape! Wonder whether it is because of the driver unit is first gen... is it still under 12month warranty?So finally after 8 months, i have a channel imbalance of -6db on my right shuoer tape bud. Any diy fix for this?
Anyways, I’m not qualified to answer but guess you check the usual (sound bore not blocked, no impact thru damp, soldering came loosen?)
If its actual driver unit failed then obviously might/might not be fixed by simply DIY
RikudouGoku
Member of the Trade: RikuBuds
Only information I found is what bggar said here: https://forum.hifiguides.com/t/bad-guy-good-audio-rankings-and-stuff-under-construction/16287/79I've heard the Tape 2 is gonna be released soon, is that true? Any details?
Basically, its going to be the same price as the tape 1, same driver but polished tuning.
Definitely a good move after what Tin Hifi did with the P2 lol.
Hopefully better QC this time.Only information I found is what bggar said here: https://forum.hifiguides.com/t/bad-guy-good-audio-rankings-and-stuff-under-construction/16287/79
RikudouGoku
yeah and no 3,5k death star peak lol.Hopefully better QC this time.
IEMusic
Now that I have the Quedelix 5K, I need to try the Oratory EQ settings on it.
RikudouGoku
Shuoer Tape EQ:
low shelf: 45hz, Q: 0.8, Gain: 1.5dB
Peak EQ: 120hz, Q:2.2, Gain: -3dB
Peak EQ: 1350hz, Q:1.5, Gain: 2dB
Peak EQ: 3500hz, Q:2.3, Gain -4.5dB
Peak EQ: 6000hz, Q: 2.9, Gain: -2dB
Peak EQ: 8000hz, Q:3.0, Gain: -1dB
High Shelf: 10 000hz, Q:1.1, Gain: 2dB
Please try this preset if you have the Tape, I like this better than the Oratory1990 preset. (This is my own preset.)
Way behind on this thread.
Stil rocking the tapes with shanling mo.
ChrisHeld1989
And another modded EJ07. Now with a matte real carbon faceplate. I think it is absolutely beautiful.
redrol
Dude you get the front seat on the Shortbus.
Thats HOT!
Thats HOT!
redrol
BTW if anyone wants a more TOTL level of treble out of the EJ, just up 15-16k by 5-10db. It actually works.
Great! Maybe I’ll try this - will it be shouty Remembered you mentioned once that Shuoer said they can’t do it otherwise will distort overall tuning (which I find a bit doubtful giving they separated by dedicated sound tubes and 15-16 are by the ESTdrivers with their own tube)BTW if anyone wants a more TOTL level of treble out of the EJ, just up 15-16k by 5-10db. It actually works.
How is this now measure up compared to MEST, dude?
redrol
I dont have a good measurement setup sadly.. but shouty nope, just more microdetails in the way upper treble. Not bad at all!
IEMusic
15-16 KHz is upper treble “air”, for harmonics. I don’t think I can really hear things above 15 KHz. It‘s the upper midrange, around 2-5 KHz that can make an IEM sound “shouty”.Great! Maybe I’ll try this - will it be shouty Remembered you mentioned once that Shuoer said they can’t do it otherwise will distort overall tuning (which I find a bit doubtful giving they separated by dedicated sound tubes and 15-16 are by the ESTdrivers with their own tube)
Total: 6 (members: 0, guests: 6)
