Today a modern good dap has same performance compared to fixed electronics.
How does the Vega 2020 sound through the M8?
Honenstly i don' t know. I have m6 proHow does the Vega 2020 sound through the M8?
I believe the main reason for the interchangeable port was to save space on the internals and for cosmetic reasons. I could be wrong with that and I’m happy to be corrected by @ShanlingForgive me for being ignorant if I am being so, but if Shanling cannot commit to updating the android OS on the M8, does that not make the interchangeable headphone port system a gimmick?
I thought the whole point of the interchangeable ports was to future proof the device?
We will be setting up distributor in Switzerland in few months.Genau. HiFiGo is the best option I have found for Switzerland.
Another reason is for the possibility to add more options. At release it allowed us to already add new 3.5Pro, we showed the upcoming RCA module and we have few other prototypes in our offices.I believe the main reason for the interchangeable port was to save space on the internals and for cosmetic reasons. I could be wrong with that and I’m happy to be corrected by @Shanling
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Don't forget the musicality of the bass....I agreed with everything you said. It isn’t the emphasis of the bass, it just has the body density and the sub-bass together with the ambient warmth , it may appear that way. It is a really good DAP for sure
If you want to know an emphasis of bass, the dx300 has it
Did you ever get this working or are we still waiting for an updated update from UAPP? I am stuck in max 96 kHz land as well after properly enabling the bit perfect driver after buying the MQA upgrade. It's a pain to use UAPP for flac 16-bit and local files (sounds great) and then need the Tidal app for proper MQA. With the Tidal app having no apparent read out of what exactly the original rate is? Just 352/384 kHz for everything. Annoying. Does it matter when listening? No, but A&K do it properly.Question to the UAPP users:
when playing MQA tracks in Tidal (or local files), do you get full unfolding? For me the resolution stays at 96KHz whereas in Shanling app I get the full 384KHz.
I hope somebody will propose a hard tempered screen protector. Because those that comes with the DAP are very annoying. 1 month of use and still has bubbles. When I put the DAP with it's leather case in my pocket, it causes more bubbles.
Thank you, I will try. I will ask andrew to send me some more.I had to request new ones as the ones in the box were dried up. Musictek sent out 4 new ones for me.
The way I found to install them correctly without bubbles was to peel of all the backing so it was just the TPU exposed and then spray the TPU with some water before installing it on the screen. I then used the squeegee applicator to apply the TPU on the screen which also pushed out the water spray.
This way allowed me to move around and position the protective TPU on the screen correctly and removed the bubbles.
