@Shanling nevermind, looks like I didn't set my foobar correctly. It play DSD512
Shanling M8 Android Portable player
- Thread starter Shanling
- Tags
- shanling shanling m8
Andromeda, with its "unique" impedance curve, will act accordingly with the M8's output at 2ohm. So overall more neutral, less bassy, less thick.Has anybody tried the M8 with the Campfire Andromeda IEM's by any chance?
I'm looking to purchase a set of Andromeda OR Solaris 2020 but wondered if they are a good match with the M8?
Thanks
Up to personal preferences if that's something you like on Andromeda or not (I personally prefer it this way).
Please reach out to Musicteck, we sent them some extra screen protectors for such case.@Shanling
I received my new M8 yesterday from Musictek. Thank you for producing such an amazing DAP. Having come from a iBasso DX300 I can say this DAP is far superior in build and sound quality. Very happy customer.
The only problem I have is both of the screen protectors included in the box were so dried out that they were unusable. The paper backing was all stuck to the TPU so could not be applied to the DAP.
Please could you get in touch with me so I can arrange replacements with you as I currently have nothing on the DAP and I would like to preserve the DAP for many years to come.
Thanks
M8 can get warmer than some other DAPs. SO just because one perceive it as warm, it doesn't mean it's faulty.You might have a faulty unit in the M8, according to the YouTube reviews I've seen, nobody has mentioned heat being an issue.
XMOS is used for USB DAC function, which is completely different from the USB Digital output.@Shanling I finally got the M8 but looks like it doesn't play DSD512 over usb. It does play up do DSD256. In your product page it says "with the advanced XMOS USB interface, M8 can serve as a true Hi-Fi USB DAC, supporting Hi-Res playback all the way up to 32bit/ 768 kHz and native DSD512" but in the FAQ document (which exist only inside the DAP) you have "6. Does M8 support digital output? Yes, M8 supports digital output. Digital signal can be outputted through USB port. Supports PCM up to 32bit/384kHz, DSD up to DSD256 in native, DOP or D2P form."
This is a blatant false advertisement. Will you ever support DSD512 over usb?
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Hellraiser86
It really could be the case. I was surprised, too.You might have a faulty unit in the M8, according to the YouTube reviews I've seen, nobody has mentioned heat being an issue.
The M8 is playing without a break since then and it really opened up. I would say it’s soundwise on par with the dx300 (just with a different flavour).
The iBasso plays about a 30% longer and the battery takes half the time to get fully loaded. DX300 is also way faster than the M8.
Concerning the heat... it gets as hot as my DX160 when it’s playing hires audio while charging. I never did this before at the same time but noticed it yesterday because I had no time to wait
Cecala
- Mar 15, 2007
Thanks.It really could be the case. I was surprised, too.
JSBachFan
Formerly known as K400Lover
- Aug 4, 2014
Did you compared them to the Stock Elysium SpinFIt tips?The Xelastec tips have emerged as my favorites as they mold to your ear canal shape so give you a quasi-custom experience balances the sound to perfection.
I don't have many tips to compare, but I did compare INAIRS AIR1 foam tips with the SpinFIt tips.
INAIRS fit way better.
SpinFit sound way better.
INAIRS take away quite some of the brilliance and the cristal clear sound that I love so much about my Elysium.
SpinFit take a while until they sit properly and have to be put back once in a while when you move. But for now it is worth it.
I was quite shocked how different they sound. To the level, that I may not have been such a fan of Elysium if I would have heard them with INAIRS in the first place.
So I am looking for tips that preseve the sound character of the Elysiums but adapt better to the ear channel.
Are Xelastecs the answer?
Btw. Thank you so much for your great reviews about M8 (and Elysium)!
I am completely adicted to M8 with Elysiums. You just don't want to stop listening to music any more. So fluent flow of music. Such an intensity and high level of musicality. Sleeping time suffers. But it is worth it.
Xelastec are great until they stretch. Unfortunately, they stretch a lot - you lose your insulation because they get too big.Did you compared them to the Stock Elysium SpinFIt tips?
These inserts had already been restored once by a hot and cold bath.
You have tried comply?Did you compared them to the Stock Elysium SpinFIt tips?
JSBachFan
- Aug 4, 2014
No, but InAirs are supposedly the same. Same principle and they look the same.
I guess the porous surface that is still peaking out of the tips (inside the ear) sucks in some treble.
But of course same looks don't necessarily deliver same sound ...
Guess I will just try with the Xelastecs. Don't like the streching issue mentioned by @mzura ...
Trance_Gott
For me Comply T400 works great my number 1. Better then CP145.You have tried comply?
Well...i always use because the tip inside my ear takes the shape of ear canal. Best solution is the tip molded like ciemFor me Comply T400 works great my number 1. Better then CP145.
And this is why I personally moved to custom IEM
all999
Tip rolling is part of the game
Ok. But if you sell is a problemAnd this is why I personally moved to custom IEM
immortalsoul
Hello, any chance to upgrade the Android version from 7 to 9 on Shanling M8? Thank you!And this is why I personally moved to custom IEM
Total: 13 (members: 0, guests: 13)
