Shanling M5s now with TIDAL - Dual AK4493EQ DAC, fully balanced, Wi-Fi, 2way LDAC BT, 3.2 Touch screen, FW 3.7
Jul 22, 2019 at 9:10 PM Post #2,146 of 2,497
I tried a card that works fine on a DX220, it's not the card. I hope you can fix it, because the M5S is probably the best sounding DAP I have tried (I have Fiio X7 mkii, Hiby R6 and Sony NWZ-X2)
Well, I wasn't asking about the card, it was more about the files. If there was some problem with some files or formatting, it could show similar problem even when you had lower amount of files there.
Will assume it's simply problem of amount of files. That was reported and awaiting fix.
Jul 23, 2019 at 5:16 AM Post #2,147 of 2,497
@Shanling , I have got an error on shuffle a playlist . After playing randomly songs on a play list (shuffle play), then turn off the device. The device can not resume the song when turning on. Would you please check? It seems to be no problem if I play the song in a playlist sequently.
Jul 23, 2019 at 5:41 AM Post #2,148 of 2,497
Tried it and seems it's working fine for me.
Are you talking about internal or external playlists? Which resume function you have set up?
Jul 23, 2019 at 8:51 PM Post #2,150 of 2,497
@Shanling I have tried:
- Open one playlist, "list play" some songs then turn off the M5s. Turn on again, M5s resumes the current song.
- Open the same playlist, " shuffle list" play some songs then turn off. Turn on again, M5s can not resume current song!
Would you please check with your M5s. Thanks
Jul 23, 2019 at 8:54 PM Post #2,151 of 2,497
I shuffle play all songs of one playlist ( songs on sd card). After turning off the device then turn on again, the M5s doesn't resume the current song. Instead, it display "life is short, play more"!
Can you please give us little bit more details? Are you playing playlist created in system or is it your own external playlist? How many songs is in playlist? And which resume function you have set up?
Jul 23, 2019 at 9:32 PM Post #2,152 of 2,497
1- I created my own play list which contains 97 songs. ( on the sd card inserted inside the M5s of course). Do you call it "internal playlist" ???
2- If you turn off the device, then turn on, the device will play the current song by default. In my case, it does not. M5s goes to the main menu with the logo shanling album art "life is short play more". I have to find the song to play again. Am I clear ?
Jul 23, 2019 at 10:55 PM Post #2,153 of 2,497
You can create playlist within our system, that's what I'm calling internal playlist. From your message I assume you have your own created m3u file and that's what you are talking about?
In Playback setting, there is item "Resume mode", where you can switch between Off/Track(beginning of song)/Location (Exact second when you finished playback).
Jul 23, 2019 at 11:42 PM Post #2,154 of 2,497
Nope! Playlist is created within M5s by M5s, no external files or whatever.
Resume mode: "on track"
Jul 24, 2019 at 11:29 AM Post #2,155 of 2,497
Same here one time its ok and it resume track position the next try it dont (opens on menue screen) and so on....
As if it only resume on "even" attempts of shutdown and restart.
Seems common issue with firmware
Jul 24, 2019 at 10:20 PM Post #2,156 of 2,497
Thank you, with this additional info I managed to recreate your problem. Reported it to software team.
Jul 31, 2019 at 11:11 PM Post #2,159 of 2,497
Aug 2, 2019 at 10:16 AM Post #2,160 of 2,497
@PinkyPowers , I was totaly convinced by your M5s review :" Possibly the best bang for your buck headphone in existence is the Meze 99 Classics ($309, Review HERE), with its gorgeous voicing, rich bass, and crystalline clarity. Shanling’s M5s does nothing to hinder the transparency, but really fattens up those mids, increasing warmth and acoustic resonances. Yes, these two pair together so well, I can’t imagine a more satisfying system for under $800..."
So, besides the awesome iSine 10, I just have bought another headphone, the Meze 99 Classics! This Meze 99 Classics just sounds fantastic with Shanling M5s via balanced port! By the way do you apply EQ on the M5s?
https://theheadphonelist.com/dark-yearnings-a-review-of-the-shanling-m5s/3/
