Shanling M5s now with TIDAL - Dual AK4493EQ DAC, fully balanced, Wi-Fi, 2way LDAC BT, 3.2 Touch screen, FW 3.7
Nov 25, 2022 at 8:27 AM Post #2,491 of 2,497
Hi, Shanling M5s is completely new to me. Is it possible to use the player for playing music files stored on my DLNA disk which is connected to the same home wifi network please? If not is there any capable Shanling player out already? Cheers!
Nov 27, 2022 at 9:28 PM Post #2,492 of 2,497
Yes, you can use M5s with your DLNA. M5s only acts as DLNA renderer, so you have to use some other device as DLNA controller(can be your phone, tablet, computer).
If you want to control it all directly on the player, look at our Android players and just install your favorite DLNA capable app.
Aug 2, 2023 at 10:46 PM Post #2,493 of 2,497
Hi, I tried to get my M5s to work with my Sennheiser Momentum Bluetooth wireless over-ears headphones, but without success. I was able to pair the M5s easily. When I didn't get sound, I tried switching codecs on the M5s. Each time I did that the M5s would briefly disconnect and reconnect to the M3W, but still no sound when playing a song. I tried APTx, AAC, and SBC. No joy. Is the M5s simply not compatible with the M3W? Thanks
Aug 2, 2023 at 11:52 PM Post #2,494 of 2,497
It's likely not compatible, Sennheiser likes to use sort of special setups for their Momentum line and we faced similar issues in past.
Oct 7, 2023 at 12:27 AM Post #2,495 of 2,497
Hi has anyone experienced issue of connection error when trying to connect to wifi network
Just started experiencing the problem - seems to connect momentarily then comes up with error
Have done factory reset but nothing seems to resolve problem - any suggestions
Feb 29, 2024 at 2:25 AM Post #2,497 of 2,497
