PierreC
Hello,
Extremely interested by this M3X, I read every page on this thread but I still have a couple of questions. If you can answer all of them that would be fantastic!
(keywords in bold to go through questions quickly)
1- What is the boot time of the M3X? (I mean, an estimation from a real shut down and not from the sleep mode)
2- Certain players rescan the entire library at every real boot, and this can't be turned off on some model. I'm wondering if, on the M3X, it is possible to scan the library only manually by disabling the auto-scan? (I know this was possible on the non-Android -based M2s)
3- I read here that Qobuz can be installed, that's a feature I'm really looking for, thanks for that. But can anyone tell me if this Qobuz version can play Gapless? (I'm using the iOS version on my iPhone and it has it, so just want to be sure it's the same story on Android)
4- Also regarding Qobuz, is the Local mode (to play Offline) supported on this device? (I ask because it looks like this Android OS has AGLO, and I'm not sure this could make any difference in term of App behaviors)
5- In term of listening, I'm interested in several specific configurations:
° DAC mode, so Macbook (using Audirvana) USB wired to M3X wired to Sony Headphones (no question here, I know it may work well, as the M2s)
° But also interesting in listening from my Desktop library or from the Desktop Qobuz App using LDAC Bluetooth, so the following config.: Macbook (using Audirvana or Qobuz for Mac) USB wired to M3X, then this latter sending the music to my Sony Headphones via LDAC Bluetooth codec -> Is this configuration allowed and if applicable, does it work well?
6- Last question, as you may expect I own a Shanling M2s (with a single AK4490EQ). So I'm just wondering how does the M3X play compared to M2s, in term of sound quality? Does the M3X (handling its 2 ES9219C) improve audio quality compared to the M2s?
That's quite a lot of questions, sorry
Thanks in advance!
Thanks in advance!
