Shanling M3X Portable Player - Our smallest Android Player
Dec 14, 2021 at 4:10 AM Post #1,606 of 2,511
As we know, the Shanling app can be buggy, so I've been experimenting with other apps. I'm thinking of trying UAPP. Question to anyone who has tried it: what's the best way to buy and install it? Directly through the player, or by transferring by PC? I haven't paid for any music player apps before, so not sure about the best/ safest way to do it. Thanks for any advice.
I just downloaded it from the play store and installed. You can try out the trial version first and if you like it then you buy it in play store and install.
No need to connect to laptop and install.
Dec 14, 2021 at 7:30 AM Post #1,607 of 2,511
The full, paid version is only available through the Google Play Store.
Dec 14, 2021 at 9:02 AM Post #1,608 of 2,511
This works better then I expected. The DAP is meant to be paired with warm headphones and smooth treble of M3X takes some edge of Z1R. Nice combo to work with at home at low volume.
Dec 15, 2021 at 5:11 AM Post #1,610 of 2,511
@Shanling - I have started facing an issue with my m3x where it has stopped charging. When I plug in the USB-C for charging, it starts charging for 1 second (red charging light comes up) and then no charging (red light goes off).
Tried hard reset, nothing is helping :frowning2:
What are you charging with? I find mine did that if I tried to use my phone charger, but an anker plug qc 3.0 works fine.
Dec 15, 2021 at 5:25 AM Post #1,612 of 2,511
Thanks for response! As of now I only have my phone charger with me (and it used to work). Will see if I can get additional charger :)
5v/2A should work fine.
Dec 15, 2021 at 8:29 AM Post #1,613 of 2,511
Same issue if I use my huawei phone charger but others work fine.
Dec 15, 2021 at 8:30 AM Post #1,614 of 2,511
Dec 16, 2021 at 1:02 AM Post #1,616 of 2,511
Yes, please try different charger or USB port on PC, that way we can see if the issue is in charger/cable or on M3X.
Dec 16, 2021 at 1:56 AM Post #1,617 of 2,511
Really enjoying this Dap.
First intended on using as a usb transport streamer, but the synergy with warm earbuds is Totl.
Dec 16, 2021 at 4:46 AM Post #1,620 of 2,511
So true they sound good out of warm set as they are tuned with neutral tonality so thin sounding will sound thin out of it like JVC FDX01
