I see we can use Apple Music in this DAP as well. I do have Apple Music subscription and as long as I am able to access it, I’m ok. I hope Apple Music does support lossless in Android DAP.You can use the Roon Remote app to play on the M3x. Unfortunately the app doesn't support high-resolution on any Android device.
Shanling M3X Portable Player - Our smallest Android Player
rlw6534
Yes, Apple Music works fine with lossless/high-resolution on M3x. No Atmos though.
rubymydear
Will check on this. Did you tested any other USB DAC?
I tried a Ray Samuels Audio Intruder from USB, with the USB output volume on 100, and while I could get a signal from the Shanling music player app, I could not get any output using Apple Music.
Have ordered a new unit and will be with me by end of this week. Needed a portable device with streaming capabilities and like Sony, Shanling has strong pedigree in making portable music player.
Just got the delivery…have 1 question can I use 20v charger of my iPhone pro Max to charge this device faster or it won’t make a difference as compared to 5v charger
rlw6534
The M3X supports QC3.0 and PD2.0 quick charge so yes it can charge faster. I have no idea what standards the apple charger supports, however.
mark88888
- Jul 23, 2010
Hi all. So I've been using the Hiby player app to play songs on the M3X. Sounds and works great. However there are 2 weird issues. 1. When I skip to the next song, before the song plays, I usally hear a little snippet of sound before it plays. Like half a second of music. 2. When I press back to go to the beginning of the song, instead it goes to the previous song.
The first issue is more of a problem than the second. Anyway... any advice? Have you also heard anything like this, with the HiBy or any other player app? Any remedies? Thanks.
This is my first android based DAP, well first android based anything
Is there a way to enable system wide EQ on it so that the EQ applies to Apple Music or Qobuz. I don’t have great music library so I rely on streaming
Hi @Shanling , the volume wheel on my M3X is becoming a bit less responsive. Sometimes 3-4 steps have to be rotated before the volume goes up one step. Any fix for this or is this a software issue or hardware issue?
Ulrich B.
The M3X does not have a system wide equalizer. You must use the respective equalizer of the app you are using. The Hiby R6, R6 Pro, New Hiby R6(2020) and Sony NW-ZX507 have a system wide equalizer...This is my first android based DAP, well first android based anything
Thanks for Info. I found a work around at least for Qobuz. Got the USB audio player pro with tone booster EQ Add-on so at least I can EQ my local music files and Qobuz streamThe M3X does not have a system wide equalizer. You must use the respective equalizer of the app you are using. The Hiby R6, R6 Pro, New Hiby R6(2020) and Sony NW-ZX507 have a system wide equalizer...
This can be hardware related to the potentiometer of the wheel. Would need to open the device, sometimes bit of lube into the mechanism helps, sometimes it needs to be exchanged. If your device is under warranty, you can reach to your seller.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
gintonic
- Jan 20, 2007
We saw few reports on this and software team is investigating.
No idea what might be causing this, especially as it's picky between apps.
@Shanling As an update to my situation, I find myself very frustrated with Shanling quality control and service. My M8 player has been no troubles, but this M3X has been disappointing from the get go. After only a half a dozen listens, it would no longer boot... off to China for warranty repair, shipping at my cost, and long wait.
Finally it arrives back supposedly repaired, but now has this new issue of many Android applications not producing anything more than statics and clicks. I tried to work through that with Hifi-go and on this forum, but it was mostly 'reset, reinstall and reboot' types of suggestions. Of course, that took more than 7 days... so now it's my fault again, and I must pay to ship back to China again. I am a sucker for allowing customer service to stretch me out past the return period for the warranty work, but this is what they did.
Will they create yet another issue in repairing this time? Will my warranty period eventually expire completely without this player ever fulfilling its niche for me? Will I need to spend even more on shipping than I did acquiring this unit brand new?
I asked kindly for a replacement unit to this lemon, so that Shanling could dissect it to their hearts content... or destroy it. I was refused, but will kindly ask again here. Please see what can be done about this customer service nightmare. My attitude toward the company is spiraling downwards, and I hope some visibility here will help my situation improve. Please see what can be done.
Unfortunately nothing, we are not sure what might be causing such issue of Tidal working while others are broken. I can't remember any case like this before on any of our Android players. Sometimes it can be caused by some conflict between apps, but factory reset or simply tuning off other apps normally fixes this.@Shanling As an update to my situation, I find myself very frustrated with Shanling quality control and service. My M8 player has been no troubles, but this M3X has been disappointing from the get go. After only a half a dozen listens, it would no longer boot... off to China for warranty repair, shipping at my cost, and long wait.
Our international distributors normally issue replacement for such problematic units. But Chinese sellers follow different warranty procedure and all units are send for repair, not getting replacement apart from very unique cases. I will try to reach out to Hifigo, if we can get this unit into our office for further check. But they are not direct dealer of Shanling, so might be a bit complicated.
mark88888
- Jul 23, 2010
As we know, the Shanling app can be buggy, so I've been experimenting with other apps. I'm thinking of trying UAPP. Question to anyone who has tried it: what's the best way to buy and install it? Directly through the player, or by transferring by PC? I haven't paid for any music player apps before, so not sure about the best/ safest way to do it. Thanks for any advice.
