- Dec 30, 2013
Back to the old FiiO X5 and x5-2 days, are we?
I'm an old-timer, so I actually started modding with Rockbox back in the day and too it up again more recently with the original X3.
OK, Let's rock!
Here is the special M2s custom firmware version based on v2.20. This firmware allows you to develop your own themes without having to reflash your player each time.
It uses the res folder on your SD card as a repository for resources. If there is no res folder, the internal player themes are used.
To make your own themes, you need:
- unzip the contents of the archive to the root of the memory card;
- flash the custom firmware (update.upt);
- edit the content of the res folder according to the current contents;
- (re)boot your player for the changes to take effect.
Please share your themes. Interesting ones will be included in future versions of custom firmware.
(If you are interested in my work, please make a donation -> go to my site on the link in my signature).
Enjoy!
All necessary strings are in res filder in the archive with custom firmware.hi , i want translate to pt br ( portuguese brazil ) , can you send me strings to translate ?
You can take the english as base, translate it at your own and test on your player.
Maybe replace the strings for other language and use it as portuguese...i create um new folder in str folder called portuguese , but dap dont detect it , i know i can replace english , but how can i add a new language ?
thanks
after restart files restore !
EDIT : really dont work .
Hi XVortex.
I know that system font is available. But I would like to know if I can change not only the font type but the size of it as well.
If not would you be so kind to give some tips according best fonts, more readible, to replace the original one?
Thanks in advance.
Jaro
