Shanling M2s Hi-Res DAP with AK4490 + MUSE8920, Bluetooth, & USB Out
Discussion in 'Portable Source Gear' started by nmatheis, Apr 7, 2017.
154 155 156 157 158 159 160 161 162 163
  1. Gokul
    Thank you so much!
    DBaldock9 and Mr Trev
  2. Gokul
    I was trying to install the m2s audio driver on Windows 10 and the software is giving this error. Please help me solve it.
    And also tell me the process on how to install (Do I connect my m2s and then install or install and then connect or connecting it doesn't matter at all?)
    Error picture: https://i.imgur.com/oWavTPT.png
  3. Shanling
    Shanling Have any question about our players? Just PM me or send me email. Stay updated on Shanling at their sponsor page on Head-Fi.
    DBaldock9 likes this.
  4. Gokul
    I got it to install. Thanks!
  5. Gokul
    So after all this, I've decided I'll get a iBasso DC 01 but the headphones I want to pair them with is the ATH M50x and it came with cables that are suitable for a 3.5mm headphone jack.
    So should I buy a iBasso DC 01 and a 3.5 to 2.5mm converter cable (will this converter cable cause a loss in quality?). Also, this picture here shows a converter cable connected. Can you link any good converters similar to this or this one? https://cdn.head-fi.org/a/10321273.jpg
    Or the iBasso DC 02 which has a 3.5mm jack?
    What exactly am I going to lose if I compromise and get the DC02 instead of the DC01? Can someone please explain the exact difference?
    Please help me out here.
  6. Shanling
    Not exactly sure why you are asking this question about iBasso here, but I will try to help.
    To my knowledge, ATH M50x has cable connected over single TRS 3.5mm jack. So without actually completely recabling whole headphones(and drilling connector to other side), they are not able to be run as balanced. So using 2.5mm cable would only mean you are risking damaging headphones or the iBasso.
  7. Gokul
  8. Shanling
    It's not just about converting 2.5mm into 3.5mm, but about going from balanced signal into single ended.
    At Shanling we recommend to use only balanced wired headphones with balanced output. Anything else is not proper connection and eventually can lead even to damaged equipment.
    And just because you can find some adapter on ebay doesn't mean it's proper one.
    Gokul likes this.
  9. Gokul
    Oh. Thank You Shanling. I'm new to all this audiophile stuff so I didn't know.
