hemtmaker
- May 25, 2013
I might have missed it. But when m0 is laid flat on a desk, touch screen does not respond. Is that normal?
I just downloaded 2.1->2.2.I am still getting the HR logo. But maybe only on higher quality files. No longer on 24bit/48kHz files which I think it showed it on before. It does not show bit/sampling rate instead of the HR logo.
I'm sure there will be a lot of moaning about not having X or Y, I'm pretty happy so far (whispers - remember position per track/podcast resume next please![]()
LOL
so much waiting and the problem 5 is not solved
The problem exist not on all albums but only on the one that are in one file and a cue sheet (the id tags are correct)
the songs listed in alphabetical order and not by their track number
If i browse via "Folders" there is no problem
For me it is big problem as i am album listener
You will do something about that or no?
PerfectFirmware v2.2 here you go!
Shanling M0 Firmware 2.2
1. Added Triple click shortcut, available in System settings
Perfect
By the way, Shanling, does the device include some screen protectors?
To sum it up how M0 can work:
mSD card in M0 -> Wired or Bluetooth headphones or external USB DAC
Phone over BT -> M0 -> Wired headphones
Computer over USB cable -> M0 -> Wired headphones
Two things we want to implement in future:
Phone over BT -> M0 -> external USB DAC
Computer over USB cable -> M0 -> Bluetooth headphones
What we will never do:
Phone over BT -> M0 -> Bluetooth headphones
Because this makes no sense(signal is affected by the codec used by phone, no matter what will then M0 use)
I am trying to download the 2.2 firmware and it says it's corrupted? I have tried several times and it is the same?
Anyone else had the same issue?
Google drive download
Shanling M0 Firmware 2.2 notes
Changes and fixes:
2. Added playback controls when using M0 in Bluetooth receiver mode, including double and triple click shortcuts
3. Added support of external m3u and m3u8 playlists
4. Added “Recently added” list in “My Music”
5. Fixed bug causing wrong song order in “My Music” browsing
6. Improved USB digital output
How to update:
1. Make sure that M0 is fully charged.
2. Unzip the file and copy “update.bin” file into root folder of micro SD card.
Note: If your M0 is on firmware 1.0 or 1.5, card must be formatted to FAT32. For update from firmware 2.0 and higher, you can use all cards.
3. Choose “System Update”in system settings and follow the displayed instructions. Wait until system restarts.
4. Check in settings “About M0” to be sure new firmware was installed.
Hi Shanling (or anyone reading this),
Is there a way to update the M0 WITHOUT using a MicroSD card?? Can I just connect it to my PC and update it that way?? Please explain how if yes.
Thank you!!
