Recovery/unbrick M0 after failed firmware update.
https://www.mediafire.com/file/u3usw94a34lrnuj/M0_Cloner_Tool.zip/file
Step 1. Extract archive, go to the folder
cloner-win32-driver and install driver. Right click on
usb_cloner_device.inf -> Install
It may need to disable driver signature enforcement or bypass on warning for unsigned driver install ('Install this driver software anyway').
Step 2. Open up/disassemble M0 device to get access to tiny button on the board (see the photo).
Step 3. Make sure that M0 is powered off. Press and hold that tiny button on the board together with power on button for 3-5sec - M0 goes to
USB boot mode.
Connect USB cable to computer. Check in the Device manager for
usb cloner device presents. If you see X0 (X and square symbols) device, install the driver by Step 1. Disconnect the USB cable.
Step 4. Go to the folder
cloner-1.0.0BH4-windows_release\ and run
cloner.exe application. Click on
Start and now connect M0 device in USB boot mode (see Step 3).
The burn process starts automatically. When the message 'Stage 1 needs reset' is appeared, reset the M0 device (you may press tiny reset button near microSD card slot or press and hold power button about 10sec) and go to USB boot mode again. When process is complete, M0 device may reboots and normally boots to main screen.
Note: this tool does similar job as update.bin v3.6 firmware, i.e. it burns only two parts - kernel and system partition from firmware 3.6.
Here is useful photos how to disassemble M0 device
https://www.head-fi.org/threads/sha...player-new-firmware-v3-6.874859/post-15011412
Recovery/unbrick M0Pro after failed firmware update.
https://www.mediafire.com/file/2z5yjt0rfuraqob/M0Pro_Cloner_Tool.zip/file
Step 2. Open up/disassemble M0Pro device to get access to tiny solder pads on the corner (it is place for unsoldered button) on the board (see the photo).
Step 3. Make sure that M0Pro is powered off. Short the pads on the board (See the photo) and in the same time press and hold power on button for 3-5sec - M0Pro goes to
USB boot mode.
Start and now connect M0Pro device in USB boot mode (see Step 3).
The burn process starts automatically. When the message 'Stage 1 needs reset' is appeared, reset the M0Pro device (you may press tiny reset button or press and hold power button about 10sec) and go to USB boot mode again. When process is complete, M0Pro device may reboots and normally boots to main screen.
Note: this tool does similar job as update.bin v1.6 firmware, i.e. it burns only two parts - kernel and system partition from firmware 1.6.
Warning! M0 and M0Pro are different devices. The tools are also different.
