Shanling ET3 - Dedicated Digital CD Transport, With USB Drive and Wi-Fi Support
Dec 5, 2023 at 8:23 PM Post #286 of 1,486
Thanks for this! Excellent stuff! I assume this works for Mac OS as well?
You're welcome.
I don't know. I'm not sure that they have a iFi Bridge app for Mac OS. If so then yes, it should work either way since there's nothing "custom" about the setup. If you have the app running on any Windows PC on your network it should work though, even if that PC isn't your Roon Core.
Dec 6, 2023 at 2:32 AM Post #287 of 1,486
Another day of musical bliss with the ET-3 DLNA streaming via QQ Music‘s QPlay upsampled via I2S into the Holo Spring 3 KTE and KGSSHV Carbon. Transducer today is the venerable classic Stax SR-X Mk1 Normal Bias (NB), circa 1970. The relative newcomer, ET-3, does not seem out of place in this company. Gorgeous music from an outstanding source with the luscious Shanling house sound. :)
Dec 6, 2023 at 1:45 PM Post #288 of 1,486
The ET3 is up-and-running [16bit/44.1kHz] via USB Audio out to the Mojo Audio Mystique Gen.1 [NOS] DAC, which in turn is running single-ended out to the Schiit LYR+.
The Shanling comes simply but securely packaged. This transport is a solidly and beautifully built unit that sounds quite good straight out of the gate, even though my set-up is not optimal yet (shelves needed).
Cannot perform an exact a/b versus the NuPrime CDT-8 with the Mojo Audio DAC [USB input only], so will have to reinsert the D400EX and compare with AES/EBU or Toslink cable. Too bad neither the Shanling nor the NuPrime can be used i2s out to the S.M.S.L.(!)
[I really appreciate the defeatable display, too!]
Dec 6, 2023 at 2:05 PM Post #289 of 1,486
Just put on the Herbie's Super Black Hole CD Mat . . . an indispensable tweak! What more can I say?
Also, I will note that the ET3 is much quicker/more responsive to the remote control than is the CDT-8.
Dec 6, 2023 at 3:28 PM Post #290 of 1,486
Really neat to see how your systems have evolved over the years. Looks like a great desktop setup!
Dec 7, 2023 at 7:11 PM Post #293 of 1,486
What is your source for a custom i2s? I need one to match the ET3 with the SMSL D400EX. Thanks!
| AVplay HD-300 99.99% Silver Hi-end HiFi Audio DAC DDC CD HD-MI i2S IIS RJ45 Digita Wire Player Connect DAC HD-MI2.1 4K 8K Cable
https://a.aliexpress.com/_msUqovI
I haven't recieved it yet. I told them the components and they were making it for their compatibility.
Dec 7, 2023 at 7:27 PM Post #294 of 1,486
MUCH appreciated! Let us know how it works out for you. More than likely, I can then follow suit [Deo volente].
When is the queue for matching your components? at check-out? [I was just over at the site.]
Dec 7, 2023 at 9:45 PM Post #297 of 1,486
Initial results are that vinyl is more dynamic and the bass is a little fuller. Let's call vinyl, a little more full and rich.
Although, the cd is DEFINITELY more convenient, which my cat appreciates. I'm looking forward to doing more comparisons. I'd also like to do cd vs streaming.
Dec 8, 2023 at 10:16 AM Post #299 of 1,486
I understand that it might be a bit pricey but the Tubulus Argentus is a nice custom I2S.
Dec 8, 2023 at 9:22 PM Post #300 of 1,486
Having a great start to the weekend with the ET-3 streaming QQ Music via QPlay (DLNA), listening with the Stax Omega. :)
