Nope! You may connect 2, 3 dacs - just keep switched on only one. Otherwise I2S is the output, it is authenticaly developed for CD. After that it is more of a preference between Coax and AES, but to me the AES is cleaner.If one wants to use the ET-3 with more than one dac (and not using the USB output) there must be only one cable connected, and not several, right?
Exemple: I2S connected to one dac and AES/EBU to a second dac.
For better sound quality only one output can be connected. Is this the correct way?
Shanling ET3 - Dedicated Digital CD Transport, With USB Drive and Wi-Fi Support
