Sennheiser Momentum vs. Shure SRH 940 vs. Shure SRH840 vs. Sennheiser HD-518 vs. Beyerdynamic Custom One Pro vs. AUDIO TECHNICA ATH PRO700 mk2 vs. Sennheiser HD 449 vs. Audio-Technica ATH-M50S vs. UE 4000 vs. UE 6000
Mar 5, 2013 at 6:55 AM Thread Starter Post #1 of 12
akash neagi
Hi there I'm back and this time I have a long list of headphones to choose from....
The list is:
Sennheiser Momentum
Shure SRH 940
Shure SRH840
Sennheiser HD-518
Sennheiser HD 449
UE 4000
UE 6000
Yes I know the list is all over the place but hear me out.
I am currently using XBA-3
In a few days will get XB400 (just for temporary use)
In July I plan on getting MDR-1R and a fiio E12 or E17 cant decide
I like to listen to mostly Clapton, Beetles, Pink Floyd, Eagles, Adele, Linkin Park, Skillet, T-Pain, Pitbull, Chris Brown, Magnetic Man and Klaypex.
I am extremely happy with my XBA-3 except at times I do think it needs a bit more bass.
That's why I'm getting the XB400 and 1R.
Please don't try to change my decision there but if you have other hp suggestions please tell me.
I'll get one of these end of this year so there is still some time as I will have to save up.....
Oh I'll get them in Australia and you can get them all around $300 cuz thats my budget......
Thanks for your help in advance.......
Mar 5, 2013 at 9:13 AM Post #2 of 12
Of the headphones you list that I have heard (Momentum, Pro 700 mk2, ATH-M50S, UE6000) I suggest you get the Momentum's. They will be a good investment and still satisfy your need for a good low end.
I would not get the 1R if you want more bass than the XBA-3.
Mar 5, 2013 at 9:24 AM Post #3 of 12
I was actually leaning towards the pro 700 mk2 or the m50....
could you tell me the difference between them and the momentum please???
I hear the momentum is a bit on the semi-over ear headphones side....
still if comfy i will look into them......
I am planning to get one of these for my bass needs....
I hear the the pro 700 mk2s are like subs on your ear  and i like the design......
any thoughts on the amp?????
i will use a s3 or note2 to listen to them....
Mar 5, 2013 at 9:43 AM Post #6 of 12
my mind is not set on any and as  i will buy them late this year i dont plan on sticking to one from now....
all I want to know are the benefits one has over the other......
I see.
Would like to help more on this, but only tried 2 or 3 models from your list :\
Mar 6, 2013 at 10:47 AM Post #9 of 12
Dang I came in thinking that there was a review, perhaps others had the same thought?
I would say the momentum, if you planning to carrying your headphones around, a case would really work best.
I'm getting a UE9000 soon. I'll let you know how if sounds.
Mar 6, 2013 at 11:14 AM Post #10 of 12
thanks for understanding my frustrations....
anyone there plz help ot
Aug 13, 2013 at 9:28 AM Post #11 of 12
If its just for home use, I would go for the 940s. Less bass than the 840, m50 and Momentums (the only other ones in the list I've heard ), but certainly more balanced and detailed than all of them. The bass is very textured and punchy.
Aug 13, 2013 at 12:19 PM Post #12 of 12
It looks like he made up his mind and got HD518, according to his profile.
