adeeb
- Nov 13, 2016
interesting. i have my baroque ordered and on the way. i normally use the stock foam tips (large) for the best fit and seal, but they still don’t sit perfectly. i need to try the spacer — anyone have a link to the rubber ring on amazon? i cannot find it locally.In terms of sealing and maintaining the seal, I'd rate them Baroque>IE Pro>stock. I'm still trying to figure out how the Baroques change the sound sig, but they sure are the best for the seal, at least for me. They are thicker than stock but thinner than the IE Pro.
i would like to try the IE pro as well — that is also foam (although a little longer), right? again, if anyone has an online link for that please share!
