ofnep
- Apr 8, 2011
for sibilance, my advice would be to go for different tips. they can have a pretty massive impact on the signature. see the graph I posted last page, those are extreme changes I could get from changing insertion depth, tips and level of seal.
the other obvious solution is to use an EQ to lower wherever you need it. maybe try around 5 / 5.5khz first and see what that does?
the cable, I felt like you at first, but cable noises are relatively low IMO. and it's light, so for most uses, I find it to be actually a nice cable. but I sure see where you come from, it feels very cheap.
thanks,
I'll look into it.
Let them burn in for a couple of days. Experiment with the tips untill you have the best fit. I still love them after 2 years, so no panic
I'll let them burn in for few more days,Hopefully it gets better. I quite like the sonics of this iem, shame about the sibilance.
