Bokyung
- Oct 14, 2010
Get EX600 if you are tight with budget.
Thank for your advice!So you think it's a problem of finding the rights tips?Yeah i've read a lot of good reviews about those comply t500 but i've seen also that they last about two months and then they have to be changed.I've spent a lot for my IE80(consider that i've come from a 50$ iem) and comply tips are "expensive" talking about tips.And i don't want to spend 20 $ every two months just for tips..others suggestions?
It you want the top IEMs regarding sparkle consider FX700, EX1000, MDR-7550. Or you can try put 2 small pieces of tape over the bass knobs and that will at a lot more detail to the IE80s and make the treble more sparkly, the mids more upfront and the bass more controlled.
The difference between the two cables is a little word, 'pure'. Which in my terms doesn't worth 40 quids. I think, there might be an almost innoticable difference between the two cables, definitely not worth 40 quids. I would go for the cheaper one.
I have no experience with durability of upgrade cables. But previously I owned an IE7, for for years. Ive never had any problems nor with the headphone itself, niether the cable. It is durable. I didnt even use the carrying case most of the time. I guess, IE80 has the same nature...
I think, IE80 is fine with almost any source without amplifier. Although I havent tried it with amplifier...
I think, only custom sleeves are better than comply tips. But its still a question for me, if it worth the money...
