nikp
- Aug 19, 2011
How are the seal on these? Do they leak? If anyone can compare these to the ER-4S/EX-1000/IE8, I would really appreciate it.
They seal just as well as the IE8 does. Definitely isolates better than the EX1000. The sound is an improvement over the IE8 IMO.
Do they leak sound?
You'd have to really be blasting them dangerously loud IMO to have them leak sound.
I have been checking out the IE8 for a long time now, but now am totally undecided whether IE80 or IE8 is the one to get.
In summary, do you guys think IE 80 is worth the price difference, or I should stick to getting the IE8 ?
Thanks.
What kind of equipment are you guys using for your IE80s? Im looking for a good portable/USB DAC/Amp to drive these IEMs (preferably one that i can use on my mp3 player and laptop), but it's so hard to make a decision. There's Fiio's offerings, but i get the impression that they are entry level. iBasso also has some options like the D-Zero, D6, and D7, but maybe those are overkill for IEMs.
Any suggestions?
Im looking to spend up to 200 euro, although i could go a little higher than that if necessary. I'll have a look at the UHA4, thanks for the suggestion. Is it better than FiiO's products?
Heard the SONY NW-Z1070 has a better SQ than the Apple's. I am thinking of getting one 64GB when it is available for sale in the States.
Lostid did you ever consider getting a DAP that won't limit your expandability? The sony sure does sound nice but its limited on-board and lack of lossless support (It may support WAV but a huge waste of space) just killed it for me.
I kinda wish I could let you hear my Studio V with you IE80s, I think you'd officially throw your iphone off the Pali look out .
I understand the lack of support for ape/flac, but I want the portability and the ease of navigating thru the playlists and tracks. I am not so keen on the idea of bringing the flash.
