lee730
- Jan 9, 2011
The HD650 shares the same sound signature that the IE8 has. So you may like the IE8 after all. The issue though with the IE8 is with its mid bass hump, and bass which is easily fixed by EQ. If you want big sound like the HD650 on the go get the IE80s when they release. If you wanna save some money to give a similar IEM a try get the IE7 from adgtron refurbishied for $99.00 at DAKmart (Sennheiser Authorized).
Hi,
i didn't have the courage and time to check the 498 pages on this, but does any of you guys have experienced BOTH Sennheiser IE8 and HD25?
I agree this is a strange request as they are way different but still, can someone comment on the following :
- sound quality between the two (i wan't flat and well defined sound stage)
- isolation (mainly used for commuting on trains/bike)
- ergonomics (cable noise...)
I have at home a HD650 that i love in every way, but as you know it's not made for going out
I'm using the shure SE110, which i find very handy (specially with short cable on iPod shuffle), but with limited sound.
I'm mainly using iPhone/iPods, and listenings to any kind of music (Classical would the test for me).
