mtoc
- Oct 22, 2015
How to mod the hd800S back to the original hd800 if we don't like the S version?
The HD800S are pretty efficient but, if you put some power behind them you do get better bass out of them.
Guys, to those who had both the 800 and 800S (or heard both), am I accurate in thinking that the major difference is mostly a less bright/smoother highs sound, along with a bit more bass?
I've been looking at the 800 for quite some time and the price seems more reasonable now (1K EUR). The 800S are costing 1.5K EUR, which is a very considerable difference.
I haven't had a chance to find a place where I can listen to both (btw if anyone can recommend shops in the Netherlands, that would be nice) but suspect that I might not care much about the sonic difference or might actually prefer the 800 since I seem to like brighter headphones (sometimes models that other people would consider sibilant/harsh like the CD3K). It would make sense to perhaps put the 500 EUR diference into a DAC/AMP (or just save it).
Something worrying me about the 800 is the reports of paint flaking. I'm quite careful with my headphones but I'd like to keep it 10+ years and to look as good as possible. Something I learned with the CD3K is that if cans sound great but start dissolving with time, you'll have a problem.![]()
The difference in the S version is also an overall more natural tone which i personally prefer. If you pair the HD800 well however, i don't see why you wouldn't like it.
I had the HD800 for a few years and the paint never came off. Just don't drop them or leave them lying around without cover. I had mine in it's box on my desk whenever it wasn't in use.
What's your taste in music like? The HD800 is maybe the best headphone ever for classical and jazz, but i don't see it ever being optimal for rock and hiphop aswell.
I see, I will try to listen to both but it will probably be hard to justify the 500 EUR difference.
I'm usually careful with headphones, so if they won't start losing paint easily, that might not be a problem. I don't tend to store them in the box, but I have a holder on my desk and hang headphones there. They rub a bit against each other but nothing that would justify damage unless the paint is really low quality.
Regarding music, I hear mostly classical/opera and rock/pop. I might use them for gaming too, as soundstage and a "holographic" sound might help with the immersion a lot (currently using the HD598 for that).
My sources are very modest however. I'm using an old Meier Audio Corda Move DAC/AMP, which I connect to either my desktop or phone.
Will probably get the Samsung Note 7 soon, which will have either the Wolfson/Cirrus chipset or Qualcomm Aqstic, but I'm not sure any of these two will be able to drive 300 Ohms decently.
It would probably make more sense to use the 500 EUR difference between 800<>800S to get a better source.
You can sell the balanced cable that comes with it for 200 euro, but the HD800 is still the better deal i guess.
I found them a little bright and thin in rock when the music peaks with growling guitars and bright cymbals. They change a lot with the amp they're connected to however, and can be EQ'ed if you'd like your rock a bit warmer sounding. I'd say it depends on your taste and the songs you listen to, as it's not a problem for everybody.
When gaming, regardless of what people assume that haven't tried them, i found them to have an unnatural sound stage as it's more oval left and right than it is front and back. It's great for everything but first person shooters where you need to be able to pin point his exact position, as everything seemed to sound a bit more distant to the sides than it actually was. It definitely took some getting used to for me, when switching from normal headphones. I prefer an open but round sound stage for those games, but don't get me wrong, it's still sounds amazing, it's just not as PRECISE as it could be.
