Sennheiser HD 700 Impressions Thread
Jun 25, 2015 at 2:20 PM Post #4,279 of 9,320
Anyone has got a recommendation for an app under $300? I've read through the thread and found recommendations for the project ember and bottlehead crack. Anyone's got any other recommendations?
Those are good ones. Tho I think the ember is better with 700s if you want tubes. But audio Gg 15 is a beast for the price and sounds great with my 700s tho I offer use my wa6 instead.
Jun 25, 2015 at 2:27 PM Post #4,280 of 9,320
Gustard H-10 is mentioned by some, was on MassDrop a week ago for $299.
I have a Ember and BH Crack but the Ember is better IMO.
Jun 26, 2015 at 10:06 AM Post #4,282 of 9,320
  Get the Gustard H10 to fill in the empty space in the middle that the Crack leaves out.
Others have said that since I have the Lyr2 and Ember the H10 would be redundant, I like the HE-700 much better with the Ember than the BH Crack due to the lower Z of the HD-700 and after trying the Lyr2/HD-700 again I still think the Ember is better, just my opinion.
Jun 26, 2015 at 4:51 PM Post #4,283 of 9,320
Yes for much less. There is an amp (not App) that really punches above it's weight called a Bravo V2.   It is for sale on Massdrop for about $90.  It is a hybrid tube and solid state.  Don't worry there is only one tube and they are sending it out with a really top notch current production tube.  If you are interested in rolling (substituting )  the tube,  it takes a 12AU7 or ECC82.  Mine came with a plain Chinese tube as stock (made by Shuguang)  but they  are supplying a Gold Lion  made by New Sensor -Russia which by itself cost $30-40.  It is a good deal.  Massdrop is also offering  the Darkvoice headphone amp, it uses a 6SN7 and a 6AS7G I Think and is about $239 I think.  You will have to check.  In any event this is an OTL with a fairly common circuit seen in headphone amps..  The tube nomenclature written for the darkvoice is all Chinese I have translated uit for you.
I haven't heard the Project Ember but it is very well regarded and also takes a single tube.  In that amp you can use a really wide variety of tubes.  If you are a tube roller (I am) it sounds like fun, but I have 2 dedicated headphone amps and a vintage tube receiver with a headphone out.  I am not sure about adding another but if I were I might add the Ember. The Crack you mention is very well loved and that is good advice.
Jun 26, 2015 at 6:20 PM Post #4,284 of 9,320
Wow thanks for the really detailed reply! That was probably a lot more than what i had expected for a reply! I'm currently using a Aune T1 so i'm guessing that's a little better than the Bravo V2?
Jun 26, 2015 at 10:26 PM Post #4,285 of 9,320
I just bought the Schiit Asgard2 HPhone SS Amp and I am happy with it thus far  (after the theoretical break-in period of course).  I was going tubes i.e Lyr2, but I didn't want or need another expensive hobby (tube rolling).  Next, the BiFrost2 DAC w/ Uber & USB, so I can hook up all my gear via one system.  Just my humble thoughts, hope this helps.
Peace and blessings,
Azeke
Jun 27, 2015 at 4:09 AM Post #4,286 of 9,320
Azeke
What are you plugging exactly to your Bifrost?
Jun 27, 2015 at 8:16 AM Post #4,287 of 9,320
Azeke
Do you find that the HD-700 is a little on the bright side with the Asgard2?
Jun 27, 2015 at 9:07 AM Post #4,288 of 9,320
My apologies rogethatmand, I haven't bought the BiFrost 2 yet, my wife told me to slow down...
 Also because I want the Uber & USB it's a little more expensive, but I don't want to skimp on these options, so I wait.
Azeke
Jun 27, 2015 at 9:26 AM Post #4,289 of 9,320
Not overly bright, DavidA , however I did use EQ to tame it a bit, of course this is also source dependent.  Again, I didn't want to get into the tube maintenance and rolling, I researched that good tubes start at ~$300.00.  I think I would never enjoy my music in my search for that perfect sound that I may never ascertain, IMHO.  I contemplated the Lyr2 as recommended by Jason for the HD700, but had second thoughts for the aforementioned reason, he also recommended the Asgard2 for the 700's.  One profound concept I learned on this forum, is the order of things:  Headphones>AMP>DAC.  So I decided to follow this process for my newly acquired hobby, (need the best bang for the buck), currently I'm running Asgard2>Dragonfly 1.0>MacBook Pro, but I digress.
I'm really happy with my purchase once I dialed it in, but initially I had second thoughts, of course YMMV.  Hope this helps.
Azeke
Jun 27, 2015 at 9:46 AM Post #4,290 of 9,320
Not overly bright, DavidA , however I did use EQ to tame it a bit, of course this is also source dependent.  Again, I didn't want to get into the tube maintenance and rolling, I researched that good tubes start at ~$300.00.  I think I would never enjoy my music in my search for that perfect sound that I may never ascertain, IMHO.  I contemplated the Lyr2 as recommended by Jason for the HD700, but had second thoughts for the aforementioned reason, he also recommended the Asgard2 for the 700's.  One profound concept I learned on this forum, is the order of things:  Headphones>AMP>DAC.  So I decided to follow this process for newly acquired hobby, but I digress and YMMV.  Hope this helps.
Azeke
Azeke,
Makes perfect sense.
I like the Project Ember for the HD-700, uses only one tube and even the most expensive is $50, most average $15-35.
Agree with you about the Lyr2, the tubes get pricy, good ones are $100/pair while really good ones are in the $200 and up range but I've found some really good ones for $40-50/pair and unless the rest of you chain (headphones/DAC/source files) are of high quality I can't tell the difference some times.
I'm not in search of the perfect sound, I like the different headphones, amps and DACs that I have for what they are and how they sound.  I listen to music for the enjoyment and not to analyze it.  The most important thing I've found is that you need good source files/RIPs if you are ever to hear what your system is capable of.  As they say "GIGO-garbage in-garbage out"
Have a great weekend
David A
