chahooa
- Jan 7, 2014
Has anyone tried the HD600 with both the schiit magni2 uber and the little dot iii?
Anyway to check for fake hd600 or something of the sort?
bought them new on ebay.
the sound quality seems pretty decent but some areas sound so harsh like every twitch stream i have to turn the volume to make it sound like they are almost whispering or else my ears hurt and start doing that closing up thing, and i cant listen to music very loud or my ears hurt as well, like i have it at lower than my normal listening volume with other headphones and i can barely stand it
Are there even fake HD 600s?
I'm pretty certain it's due to the "peak" between 3 and 4 kHz that you can see on Headphone.com's frequency response graph. I looked it up when I got my HD 600 as I noticed this brightness in the lower middle treble (not that it is bothering me), and it pretty much reflected my own perception.
You are experiencing listening fatigue from them, I had fatigue issues with the HD 600 myself and a similar closing up issue with them, you are likely sensitive to the 3-4khz region possibly also the bass. I had a similar issue, both the HD 600 and HD 650 fatigued me. I found on the HD 600 the 3-4khz region and the bass fatigued me, while on the HD 650 it was the bass.
As for fakes, it's unlikely it's fake. Though look inside the earcup grills and see if you see a little hologram with the Sennheiser logo.
Is that something i can try and EQ out?
never messed with eq before so i have 0 idea
There is only a hologram on the right one
if it's really that bad, then it is not due to its normal frequency response. It's broken. May need new drivers. Send it back and get a replacement from the seller (if it's an authorized seller).Anyway to check for fake hd600 or something of the sort?
o2/odac combo
o2/odac combo
