Well you seemed to imply that the HD600 doesn't change or improve with better amplification, a point which I disagree with. Of course we should let everyone form their own opinion on how concrete the differences may or may not be. So if someone does notice a difference between different components I feel the need to chime in before the "it all sounds the same" mob blacks out the sun. I guess it bothers me on a certain level to know that a lot of HD600 lovers aren't getting the most out of it because they think all amps/DACs sound the same. Live and let live....it's their system not mine
FWIW, I was part of the first wave of people to build the O2 and I was convinced it was the pinnacle of audio amplifier design based off the philosophy behind it. Then I was stupid enough to listen to other gear :eek: So when you say "good quality amps are every easy to find", maybe we should examine that a bit more...or not, easier to leave that definition ambiguous so that we can both "agree"
At this point, I'm probably
. Audio is a funny thing like that.
