James-uk
- May 22, 2013
Oh I forgot to mention, I also chose the 650s over the 600s because I prefer their flavour even though I think the 600s are a better HP.
Awesome, thanks! Maybe I will get an ODAC to compliment my O2.
...and you can always consider getting a tasty, flavorful DAC to compliment your O2...
Just pulled the trigger on a pair of HD600's from the classifieds! Pretty excited.
I have a question for you guys. I already have a pair of DT770's and an Objective2 amp. Will the O2 run the HD600's nicely, or should I invest in a new amp as well? Regardless, I am going to get a DAC since I will be listening from my PC.
I think getting a transparent dac is better because it provides a platform to have the best if both worlds. He can then have the O2 for a clear window into the recording and also have a tube amp to tube roll with until finding his flavour of distortion .
The HD600's are not that hard to drive. Some people would make you think that it needs all sorts of fancy amps, but the HD600's are not as finicky as some make them out to be. An amp has be be able to make enough voltage at 300 Ohms and be clean, the HD600's are pretty sensitive and don't need as much juice as the HD650's or HD800's. Why not give it a go and see how you like it. Which impedance is your DT770's?
You could buy an HD 600, a Magni, and a Modi and not ever need anything else.
Either way works really but my logic is that the source should always be transparent , it doesn't really matter as long as the end result is the same. Oh and I have the HD800s that's why i didn't want the 600s . I needed some warmth in my lockerYeah but you bought the 650s so we can't really trust what you say!![]()
Actually what you say makes sense if one wants more than one amp.
I always thought a tube DAC and the O2 would be a fun combo or that if I had a tube DAC, I'd want a transparent amp.
I have tube amps but still prefer 'musical' NOS DACs...so what do I know...
I would still want some kind of source so I could listen to music...![]()
LOL, I'm now enjoying some loud thrash metal on my HD600s... and before that some dubstep. And before some jazz and classic rock.
Love versatility!
