Keithpgdrb
Sponsor: ZMF Headphones
- May 22, 2008
This isn't the forum for going into a lot of detail, but basically, when most people say "balanced" they are really talking about a "bridged" amp. That's two amps in one chasis - one for each channel. In theory, a bridged amp is better because your splitting the "work" between two amps. The reality is that one amp properly designed and sufficiently powerful to drive a pair of headphones will not be working hard at all so there is no need for "two amps" in one box. If a person states that the balanced output sounds better than the unbalanced output, I bet the comparison was not performed with precise volume matching or blind conditions - two requirements for accurate comparison.
Balanced is simply a wiring method to reduce noise/hum in long cable runs. Not a factor in home audio.
Unless you have heard it, you shouldnt assume a result. You are correct that this is not the forum for a lot of detail. Those wondering about balanced setups should do some research on how it actually works. There is actually a decent write up on Wikipedia. It is more then just splitting a signal. There is phase inversion, separate ground, etc..
When I listened to the eddie current example which has both SE and Balanced out, the difference was obvious. I have done similar comparisons with cans like the aka 701. if you can do a side by side, the difference is easily heard.
ok, so the hd600.. is awesome.
