HD600 arrived I'm suprised its not bad, imaging & details are there but the 660s does it a bit better, that soundstage helps it, the HD600 seems to make you a bit claustrophobic. HD600 seems to have something going on with the highs it reminds me of the sound you get from a decent amp'd car stereo with seperate tweeters running off a Amp.
The HD6XX & HD660s seem easy enough to power & run but the HD600 defintly needs more power & volume using The Element to run them. (Sennheiser GSX1000, Jotunhiem & Schiit Stack back this up)
The HD660s have a liveliness to the sound that makes the HD600 sound a bit dry by comparsion.
Initial thoughts since i have all 3 in front of me:
I'm going to grab the HD600 for Metal! (just to clarify Western metal doesn't sound as good as 660s with Eastern), selling the HD6XX & using the HD660s for everything else including Gaming.
HD6XX seems mid focused & bit more bassy compared to the other 2 ~maybe not more bassy but you hear it more easily with this headphone, some soundstage & some imaging but also lacking in it, feels incomplete. But it has a full body sound. But overall that full sound comes off very Generic sounding to similar to closed back gaming headphones when you remove the software eq. Female vocals came through intimate & male vocals came across a bit shouty.
HD660s has soundstage & imaging (Very accurate imaging!) but feels like its lacking that full body sound (Usually you would say sounds airy to explain this, but its not airy.. still trying to figure out how to explain this....), good clear highs & bass that shines through with a good Dac.
HD600 seems neutral, little to no soundstage very intimate with anything thrown at it except the highs are even closer to my ears than the rest of the sound giving it a false sense of depth to the sound at times, The highs shine through in the imaging more than most other sounds, This headphone also has a full body sound to it. Also turns out you can game with them, not the best experiance but far from the worst.
Going to spend some more time with them all, a week with each, see how my opinion changes over that time.
