ImperialX
- Apr 25, 2011
Originally Posted by estreeter /img/forum/go_quote.gif
there should be a pair of oven mitts in the bottom.
I didn't get one! Gasp!
Hey all, don't know if this is the place to be asking but here goes anyways. I just got my Lyr in the mail a few days ago, and Regardless of the cans I plug into it, I hear this high pitched background noise that's like an echo of fingers brushing on the aluminum chassis. I can't EQ it out either. Is there something wrong with the amp or does it have to do with my cans?
Cheers,
Are any of the Schitt (Lyr, Valhalla or Asgard) "Burson killers"?
Lyr is for high impedance phones. What are you plugging into them?
Well aware of this. I have tried some very low (Denons) and some moderate (DT770s) and it still persists.
I'll try reseating the tubes.
Resat the tubes, noise still persists. I think I'm going to send it back and get an Asgard instead.
Cheers,
Yes, the Burson HD-160.
To be honest, though Schiit has piqued my interest with their no-nonsense designs and apparent good value, so far I have not yet found, for my aims and needs, a Schiit product that I would purchase. What they need to do is to scale up the Asgard to go head to head with the Burson. If you haven't noticed there really aren't a lot of fully discrete, pure class A amps under $700.
Contact Jason/Schiit and tell them your tubes are likely bad. I would try another set of tubes before swapping for an asgard. Asgard's a good amp (used one for a year), but unless you have your eye on low impedance headphones, Lyr can do so much more with medium and high impedance headphones - and hard to drive orthos. You're likely dealing with a bad tube. If it proves not to be a tube, Schiit will swap your amp quickly.
Cheers,
Cheers,
