Paladin79
Previously MOT: Cables For Less
I did not notice a lot of difference with replacement tubes to be honest, I preferred the sound of the Lyr 2.
Me too. I rolled a bunch of the great 6922 variants, and the differences were small. However, once I got an adapter and put the WE396a in the Valhalla 2, things started to change, quite a bit, for the better. I don't like using adapters, but with this amp I did.I did not notice a lot of difference with replacement tubes to be honest, I preferred the sound of the Lyr 2.
I bet that sounds good, but I could never get past the looks to try it.I have a myriad of adapters. I often go with single triode tubes as well as changing tube types. I have lots of choices and own a lot of tubes, and tube amps.
I notice a bit better separation going with single triode tubes but you need to buy the adapters then shop for tubes you like. I do have some with more standard configurations.
The Freya in particular already uses 6sn7's and there are plenty of good choices around for it.
That is a Cary SLA 70 Mk II power amp from the mid 90’s, the Freya is its pre-amp.What is the bluish colored tube amp in the foreground? Is it a headamp???
Cool setup @Paladin79 !
i have the long distant cousin, Hercules, as my power amp... it’s from Cary audio’s division called Audio electronics, and i truly love it! i can’t imagine how awesome it would be it’s big cousin...
Hah! That actually comforts me tremendously.With the stock tubes, it doesn't even sound like a tube amp.
