Jacobh
- Jul 18, 2001
anyway, when i was setting vahalla 2 amp, i feel like the taller tubes are kinda loose, comparing to other tubes (or tube sockets) of vali 2 and vahalla 2's short tubes.
I have a newly purchased Valhalla 2 that behaves the same way. The power tubes don't move on their own, but they don't sit completely flat so they will move side to side easily. I didn't see any visual issues with the sockets and it's not having any impact on performance, so I assumed it was just an issue with the bottom of the tube not being completely flat or the pins being a bit narrower than the driver tubes. I'll try the driver tubes in those sockets and see if it makes a difference. The driver tubes will not move at all side to side.
So the short answer is this seems normal based on my unit.
