rovopio
- Jan 18, 2014
The Wyrd made my connection to my computer much more stable. I had been having the signal drop out and needing to disconnect and reconnect the USB to reset. Never happened again after installing the Wyrd. For SQ YMMV. But if you are having USB connection issues I can highly recommend the Wyrd.
As for cables I use Straight Wire for all of my interconnects (RCA, USB, optical and coax) and Pangea for all my power cables. Both companies manufacture high quality cables.
Can I ask you for Straight Wire ebay links or stores? They don't show up under Asia eBay, but normally I can still buy them (depends on the eBay seller). Normally this happen when the eBay store doesn't put Worldwide. When they only put select countries, it doesn't show up on Asia eBay (which is determined by delivery address).
EDITED :: Never mind, I can apparently circumvent the eBay restriction by searching through Google. Duh! Sorry
