bretemm
- Feb 23, 2015
But, is it bad to use 2 different length cords? 2 6in and 2 3ft? Untill I get another 2 6in cords? Thanks
It technically will work. You just have to be careful and remember to turn the volume down if you want to plug anything into the valhalla2. Any preamp will work as a pass-through or line out with the volume all the way up it is generally best to only use one volume control in a chain so you aren't messing with the signal to much. The main thing is since the valhalla2 is so powerful you have to remember the volume control on it before you do anything else like plugging in other headphones.
As far as the cables I would see if you can get the 6 in to reach from the modi to the valhalla2 with them sitting side by side then use the 3ft cable to go to the magni as the preouts are further in than the inputs on the valhalla2 and the magni can sit on top of the modi beside the valhalla2 and not have heat issues.
