MWSVette
How do you connect your system if I may ask?
So it goes... PC -> USB -> Fiio E17 -> ? -> Stereo Female to 2 RCA -> Lyr -> Headphones right?
What do you connect the fiio e17 and that stereo female cable with (the in-between)?
As for my situation... at the moment I have...
PC -> USB -> Fiio e10k -> Mini to 2 RCA (link) -> Magni 2 Uber -> Headphones
Now if I'm getting a Modi... I want to be still using that Mini to 2 RCA cable, instead of getting 2 RCA to 2 RCA cables. Can I get away with something like this?
http://www.amazon.com/C2G-Cables-40424-Stereo-Y-Cable/dp/B001B8QUS6/ref=sr_1_2?s=electronics&ie=UTF8&qid=1436780289&sr=1-2&keywords=female+mini+to+rca
And will there be any deteroriation in Signal or Sound Quality or anything of that sort...?
thank you for the help as always guys...![]()
The ? is a Fiio E09k desk top amp that my Fiio E17 docks with that I use as a preamp. The E09k has an RCA preamp out. In this configuration I use a Pyst RCA cable.
If I was only using my E17 as the dac it has a line out that uses 3.5. In that configuration I use an Male 3.5 to RCA.
As far as continuing to use the mini to RCA you would need another cable that went RCA to 3.5. I would not recommend that. The fewer connections the better.
With the Modi you will want to use RCA to RCA like the Pyst cable or again Monoprice makes a quality cable for less money.
https://www.amazon.com/gp/product/B003L1717K/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Something along the line of:
PC -> USB -> Modi ->RCA to RCA -> Magni 2 Uber -> Headphones
